Accord 2011 engine vibrates when start accelate
Old Jan 18, 2014 | 04:32 PM
linges's Avatar
Default Accord 2011 engine vibrates when start accelate
Accord 2011 engine vibrates when start accelate esp when ac turn high. Uphill vr slow moving. Pls advice.
Old Jan 20, 2014 | 08:14 AM
Suggest to inspect motor mounts. Usually front or rear mount is source of problem.
Look for excess movement w/ e-brake set and foot firmly on brake pedal also while applying rapid throttle inputs to 1500-2000 rpm. Observe from side of vehicle! Look for damage to rubber mount or excess movement.
Old Jan 20, 2014 | 05:00 PM
mclasser's Avatar
+1 on the motor mounts. Are you still under warranty? If so, dump the car at the dealer and have them check it out. Three years is too early for motor mount issues.
Old Jan 21, 2014 | 08:57 AM
linges's Avatar
Hi.thank you so much for the advices. In deed I when honda services nd checked the engine mounting and other causes of the vib. The mechanic the mounting are still in good conditions. According to them 2.0 model has this prob cause of under power. And its hard believe its.
Old Jan 21, 2014 | 09:02 AM
linges's Avatar
Hi, thanks for the advice, ur rite the mounting seem to be ok but they said model comment underpower prob. Kind or regret now. I plan add namo voltage stablizer, ground cable and namo filter, to increase the power, and comment? Regards
1108wing
Mar 23, 2013 07:22 PM
ABHISHEK05ACCRD
Jan 30, 2012 11:27 AM
ReadyToRetire
Sep 15, 2010 08:54 AM
upintheclouds90
Jul 19, 2010 11:49 PM
mikepsca
Dec 16, 2009 01:06 AM
