Accord 2012 Actuator Replacement
Old Dec 20, 2016 | 06:03 AM
roreru's Avatar
Default Accord 2012 Actuator Replacement
I need to replace the actuator that power locks the rear-left door of my 2012 Accord. I removed the door panel, and there is a screw that holds the level connecting the actuator, which I think needs to be removed along with the 3 screws on the door side.
The issue I am having is hard to see the connection behind the door metal held by the screw, and I have not found on the web any description to connect the actuator back. I would highly appreciate any help.
thanks
roreru
Old Dec 20, 2016 | 12:59 PM
There is a plastic clip that needs to be rotated off the outer handle rod.
There is a hole seal that covers an access hole. Remove the seal to see better. Also a clip remover tool can be used to reach through the access hole.
After that, remove the latch/actuator 3 outer screws and remove unit from inside the door panel.
buzzard86
Dec 20, 2019 05:47 PM
grim_reaper
Aug 9, 2012 12:21 PM
Hondamagic
Aug 6, 2012 12:51 AM
WICKEDPHOTO
North East
Feb 16, 2012 02:33 PM
