Accord 3.0 EGR Flow
2001 Honda Accord 3.0 V6 - 203,000
Regularly serviced, well maintained. CEL came on, was throwing P0401. Cleaned the EGR port, reset CEL and it came on 6 miles after driving. Cleaned the EGR port again, reset CEL and it came on 10 miles after driving. Cleaned the EGR port again, reset CEL and it came on 11 miles after driving. TCS light is coming on and off randomly as well, I know this is a sympton. I decided to replace the EGR valve, light still is coming on. I'm attaching photos of my EGR port, they appear to be very clean...they weren't stopped up in the first place really. Can someone please advise on something else to try, this is very aggrevating.
Thanks in advance!
Thanks in advance!
I'm missing something, what do you mean test the valve on the car and see if it stumbles? I replaced the EGR valve with a new one and still got the code after I reset it. I googled 2001 Accord and P0401 and that is why I cleaned the ports, after reading many threads and watching several youtube videos that's what everyone was suggesting. Let me know what you mean my test the valve on the car, I'm lost there?
you need 2 jumpers with alligator clips. disconnect the electrical connector at the valve. connect the postive (from batt) to the bottom left pin of the six pin connector on the valve. start the car and let it idle. connect the neg (from batt or other known good ground) to the bottom right terminal on the valve. the engine should stumble or stall...if not, either the valve is bad, the ports are plugged (both i'll assume you've addressed) or the computer is bad at that point. computer being bad meaning it's not sending a signal to the valve when it should. clear as mudd, ehh???
ahhhh...also just found a TSB 99-085. related to your specific problem...intake manifold has to come off to clean out the ports.
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
I've have that bulletin, I've removed the intake manifold 3 times. I've just got back to the office after having my catalytic converter checked...it's not stopped up. Had the shop reset my CEL with the computer to make sure I'm not getting a ghost code. Light came on 9.5 miles into the drive. Should I be able to run a coat hanger from the EGR valve all the way through the port to the intake manifold? I really appreciate your help on this.
