Accord Brake Pad change
Old Sep 24, 2008 | 01:56 AM
ulnv4ever's Avatar
Default Accord Brake Pad change
I got a question about changing the front brake pads on my Accord. it has ABS brakes. after i open the caliper, I would need a C-clamp to push the piston in to allow enough room for the pads. some people say pushing in the piston would damage the ABS braking systems, others say it's okay. Will it damage ABS? is so, what's the best way? open the bleed valve?
Old Sep 24, 2008 | 09:21 AM
klrspz's Avatar
Default RE: Accord Brake Pad change
I've done it on my accord fine without any issues... and i actually didn't use a c-clamp, but rather some elbow grease, a rag, and a crescent wrench (just to get a good level push)
Old Sep 24, 2008 | 09:33 AM
finch13's Avatar
I believe it's the rear calipers you have to be careful with. I've heard you have to turn the piston as you push it in. I may be wrong though, I've never owner any cars with ABS.
Old Sep 24, 2008 | 11:04 AM
08coupex's Avatar
A lot of people have told me the samething, i`ve never had a problem with any car so far.
Old Sep 24, 2008 | 11:08 AM
falkore24's Avatar
I've used a C-clamp before ..... I prefer my 16" channel locks though ..... easier to work with.
Old Sep 24, 2008 | 04:34 PM
jerrym's Avatar
Almost A Senior Member
I never had an issue with my Accord and ABS after pushing the pistons back in the caliper.
I did own a Camry that the piston was flat with a notch in it, after trying to push it back with no success, I found out that type you actually screw in.
Donda
May 17, 2014 03:49 PM
MessAround
Oct 21, 2012 09:36 PM
CarConfused
Sep 12, 2012 11:40 AM
Accord22
Jun 16, 2009 05:07 PM
RogerB34
Apr 24, 2007 10:10 PM
