Accord mk5 climate control faulty
Old Oct 6, 2012 | 03:11 PM
quad121's Avatar
Default Accord mk5 climate control faulty
Hi all. I've got a problem with my climate control. You can set it to low or high but it doesn't change the temperature it seems to be fully on (hot) all the time. Even if the a/c is on or off it doesn't affect the temp?
Could it be a sensor? Or something
Thank you in advance
Paul
Old Oct 7, 2012 | 06:12 AM
What year is this?
Check this thread for a possible way to get codes from the HVAC : https://www.hondaaccordforum.com/for...threads-40780/
Old Oct 7, 2012 | 07:11 AM
quad121's Avatar
What year is this?
Thanks for your response its a 2001
Old Oct 12, 2012 | 10:27 PM
quad121's Avatar
I've removed the unit from the dash but all wires seem to be in place. Also I've noticed that randomly the coolant temp gauge shoots up to the top and if you tap the cluster it then falls back to the midway point. When left idling the cooling fans kick in constantly after a short time. I've checked the hoses the top and bottom hoses are hot but the rad seems to be quite cool to the touch
Zmanj87
May 6, 2013 04:47 PM
ufosearch
May 18, 2009 03:10 AM
greenbean
Sep 21, 2007 03:14 PM
Jeffmo
Aug 15, 2007 07:56 PM
Erinsaccord
Aug 14, 2007 08:50 PM
