Accord stops running after 5 seconds
Old Mar 29, 2012 | 11:38 PM
1994accord's Avatar
Default ? after it starts
Originally Posted by jwood
Hello all, I have a 96 honda accord 2.2l non v-tech that stopped running this past weekend. The car will start if I give it some gas but will only stay running for a few seconds.
After you get it to start, how does it idle?
I have a 94 with the same motor and am having a similar issue with mine. After mine starts the rpm drop to a rough idle after it warms to 4-500rpm then drops more and stalls. I can continue to give it gas and drive it...but it stalls anytime.
If its a rough idle there is a IACV on the back of the throttle body that you may need to clean the screen on.
Mine is still idling rough and stalling...but I have read the IACV can be common issue
Old Mar 30, 2012 | 09:07 AM
jwood's Avatar
Once it starts it will rev to 2000 rpm then drop down to 700 then it dies. I cleaned the screen on the IACV when I got home yesterday and it seemed to start easier but still has the same problem. It did run for a little bit longer than normal about 30-45 seconds.
Old Mar 31, 2012 | 07:59 AM
When it does this, does it start right back up and go thru the same cycle?
Old Mar 31, 2012 | 06:46 PM
jwood's Avatar
Yes it will do the same thing for as long as you want to turn the key.
Old Apr 1, 2012 | 07:22 AM
Can you keep it running by giving it gas?
Has there been any recent work done to the car besides what you have listed (tune up and testing a few things).
Old Apr 1, 2012 | 10:13 AM
1994accord's Avatar
Default Sounds like what is happening to mine
I unplugged a vacuum line on the driver side of the manifold that runs against the fire wall. There are 2 metal tubes against the firewall, the 1 that it was hooked to continues a 3x8"ish canister. I simply hooked it up to the tube that is open on the other side.
This is NOT a fix...just a band aid. My CEL has not tripped, but it keeps it from completely stalling.
I commute 100+miles a day to work...this is my Daily driver. My truck gets 10 mpg do to low gear/big tires. My car runs great, just doesn't idle
Old Apr 1, 2012 | 11:02 AM
  #17
Have you tried to set the base idle. Disconnect IACV and open/close air bypass bleeder (TDC of throttle body intake) to get about 550 +/-50 rpm. If this is not possible, you may need to adjust the throttle plate stop. I understand that you adjusted this earlier (should never be touched!). I would set air bypass bleeder to mid position and adjust throttle plate stop to achieve the spec rpm stated above.
Old Apr 1, 2012 | 12:53 PM
  #18
jwood's Avatar
If i try to give it gas it stalls out and dies. Nothing else has been done to the car besides what was stated.
Old Apr 1, 2012 | 07:12 PM
  #19
I got you mixed up w/ another poster. If you haven't adjusted the throttle stop screw, try the base idle adjustment.
Also you need to clean the ports the IACV uses to bypass air around the throttle plate.
Old Apr 1, 2012 | 10:33 PM
  #20
jwood's Avatar
Default 1996 accord has no power under acceleration
Hello all, I have been having some problems with my accord. With help from this site the car will now start but has no power while accelerating almost like a lack of fuel or too much back pressure. I am not sure where I should start. My gauge is not accurate but I have consistent fuel pressure up to when the engine shuts off. Thanks to all that have helped with the ongoing process.
