Accord trouble turning over - "da ta ta ta ta ta vrooom" - 2005
Old Jan 13, 2013 | 08:49 AM
kelcey30's Avatar
Default Accord trouble turning over - "da ta ta ta ta ta vrooom" - 2005
even when my car is hot, starting the engine takes longer than it used to. rather than starting immediately after turning the key, the engine turns but you hear, "da ta ta ta ta ta vroom", it starts.
it's not the battery, and I replaced the spark plugs
Old Jan 13, 2013 | 09:31 AM
Is starter engaging but turning engine over too slowly to start? If yes, the check your battery connections carefully for corroded connections or corroded wires.
If all connections are good, you could have weak solenoid contacts that won't allow enough current flow to enable good starting. Starter replacement is usual fix.
Old Jan 13, 2013 | 12:57 PM
kelcey30's Avatar
Default starter
thanx, Tex. the starter was my next thought as well. the battery is new, and the cables appear clean (except for the goop they sell with the battery) and tight. will look next at starter.
Old Jan 13, 2013 | 01:27 PM
This may or may not be related to your starting problem; but, may be worth a shot. There was a recall regarding faulty fuel pump relays before.
Honda TSB 07-020
Enter your VIN at the Honda America site, to see if your car is part of this recall or if it has already been done.
Honda Automobile Recall Information
Old Jan 13, 2013 | 04:21 PM
kelcey30's Avatar
thanks again. will check
Old Jan 15, 2013 | 01:55 PM
kelcey30's Avatar
Default fuel pump
Honda dealer diagnosed a problem fuel pump. they said it doesn't require immediate fixing, but it will continue to deteriorate. their fix is $600. wow!
Old Jan 15, 2013 | 06:01 PM
If your description of poor starter turn-over is correct, they are full of it. Fuel pump has nothing to do w/ engine turn-over.
Also engine runs OK once started, so fuel pump only affecting starting is very unlikely IMO.
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
huhdo
Aug 30, 2012 09:06 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
