accord will not start
Old Aug 20, 2008 | 03:11 PM
patrickz's Avatar
Default RE: accord will not start
i just tried the engine code thing, and it only had one of those blue plugs. i used a small paper clip, and it gave me the code "22" through the redSRS light.
on the link you gave me it said "Note* It has come to my attention that some 96 Accords have a service connector behind the ashtray" i have a 96 accord and i remover the ashtray and found a connector. it has many holes, and i dont know which ones to use.
thank you so much
Old Aug 20, 2008 | 04:56 PM
That SRS code is for the passenger air bag and it is either (2-2, or 1-1) and will not cause your car not to start.
That 16-pin connector behind the ash tray will hook up to any OBD code reader to pull off more detailed codes (P#### is how they are reported). Since your car isn't running, you can't drive it to autozone to get the codes read for free. It isn't worth buying one, since a paperclip will also get the code for you.
As long as you shorted the blue two-pin connector and NOT the one with three wires, then you found the right connector.
If the check engine light didn't flash any codes, then there are likely no codes stored on the ECU. I can't remember what the check engine light does if no code is stored (either remains on, shuts off).
Old Aug 20, 2008 | 05:00 PM
patrickz's Avatar
ok
how do u recomend i get it read then?
i went back through the engine today, and all connections are correct and secure to the best of my know how.
Old Aug 21, 2008 | 07:40 AM
patrickz's Avatar
then how can i find the codes?
Old Aug 21, 2008 | 04:22 PM
If the CEL did not blink any codes when you had the connector shorted, then there are likely no codes stored on the ECU. I was hoping that something obvious would come up.
Have you pulled a sparkplug and tested for adequate spark. Without this info, its hard to give you more detailed instructions.
Old Aug 21, 2008 | 07:38 PM
You may have a fuel leak on one of the injectors at the top where injectors engage the fuel rail. Unless you lubed all the orings carefully, it's easy to displace the oring when you install fuel rail and have a leak. A leak will cause loss of fuel pressure and no-start. It may be necessary to remove the fuel rail and lube all the orings, and carefully re-engage fuel rail to injectors.
Old Aug 24, 2008 | 04:44 PM
  #17
patrickz's Avatar
there are no leaks
Old Aug 24, 2008 | 05:30 PM
  #18
Have you verified that you have spark getting to the spark plugs?
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
OldFox
Dec 27, 2005 05:51 PM
