Accord will not start
Old Jul 27, 2013 | 11:04 PM
eickhorn's Avatar
Default Accord will not start
I have a 2003 Accord. It wasn't been driven on a few months and when I tried late last night I found the battery dead. I attempted to jump it for over an hour.
This morning , I took the battery (6 months old ) to the shop and they said it was almost dead. They charged it for almost 4 hours. when I arrived , they placed a load on it and stated it's fine now.
When I installed the battery, I got no dashboard lights, no starter turn, nada. I also tried another battery from my Highlander, nothing helped.?
Old Jul 28, 2013 | 12:35 AM
Does it not crank at all. ?
Old Jul 28, 2013 | 12:39 AM
Also ...is this an automatic trans car?
Old Jul 28, 2013 | 12:42 AM
One more ? 4cyl or 6 cyl.?
If you put what it is down in your signature ..we would be able to help you much better..
Do that thru your Link here https://www.hondaaccordforum.com/forum/usercp.php
Old Jul 28, 2013 | 05:09 AM
eickhorn's Avatar
Okay
Auto, 4-door, less than 75K miles
Doesn't do anything. Turn key, no lights on console, doesn't turn etc. Just like very dead battery.
Old Jul 28, 2013 | 08:33 AM
Check the battery cables and be sure they are clean and tight. Also check the "other" end of the ground cable.
Next check the fuses in the underhood fuse box - look at the large amp fuses.....do you have a volt meter or test light?
Old Jul 28, 2013 | 01:18 PM
Maybe Auto Trans not completely engaged in park, starter solenoid faulty causeing battery drain, Ignition switch faulty and loose in colum?
Things to have checked.. Hope some of this helps member.
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
OldFox
Dec 27, 2005 05:51 PM
