accord wont start
Old Dec 19, 2011 | 05:02 PM
handtheaccordova's Avatar
Default accord wont start
i just got a 1995 honda accord for free of course it doesn't run so my problem is i have spark i have fuel to fuel block but it won't start it will turn over
so what i have done is drain old gas put new in put new spark plugs in it and i held the spark boot to test for spark it did spark the only thing i can think that could be wrong is injector failure
i was just wondering if i can get some input before i buy new injectors
Old Dec 19, 2011 | 05:39 PM
What can/did the PO tell you about it...meaning was it running and they parked it one day.
Check for weak spark, was it blue or orange?
You can put a meter on the injectors to see if it is getting power. Did you open the butterfly and try spraying carb cleaning inside.
Compression test?
Old Dec 20, 2011 | 03:52 AM
it was running when parked i guess it was sitting for 6 years in garage
the spark was blueish white i did spray some starting fluid in it didn't seem to do anything.
i so next thing to check is compression and injectors
Old Dec 20, 2011 | 06:12 PM
Well if you introduced a fuel source and it did not start, then I personally would not worry about testing injectors......
Check all the wires, might as well pull the plugs and replace or clean.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
