94 accord wont shift to gear / out tail lights
Old Dec 20, 2011 | 04:21 PM
ErikS88's Avatar
Default 94 accord wont shift to gear / out tail lights
Hey guys new to the forum here,
I have a 94 accord 5 speed, I started my car up this morning and it won't shift into any gear at all. My roommate also noticed my tail brake lights were both out.
From what I've read in the chilton manual I'm thinking it could be the brake light switch?
Any ideas?
Old Dec 20, 2011 | 04:35 PM
Failure to shift (you can access the gate but trans won't engage) is usually result of clutch hydraulics (master or slave cylinders). Fluid leaks away and clutch is not released when you press the clutch.
Brake lights could be a failed brake light switch. Check that switch is springing open when brake is pressed.
Old Dec 20, 2011 | 04:37 PM
ErikS88's Avatar
Thanks for the reply, I recently had the master cylinder replaced, and ill check the brake switch to make sure its engaging, but any other ideas why it might not go into gear at all?
Old Dec 20, 2011 | 05:09 PM
crispin's Avatar
He was talking about the Clutch Master not the brake master.
Check the fluid level on the Clutch master
Old Dec 20, 2011 | 05:20 PM
What are symptoms? Does shift feel like clutch is not pressed or you can't reach any gates?
Clutch is most likely. Investigate this before worrying about more exotic.
Old Dec 20, 2011 | 05:28 PM
ErikS88's Avatar
Checked the fluid level and it seems to be fine, The shifter just will not move into any gear at all like its locked in neutral for some reason
Old Dec 20, 2011 | 06:20 PM
Open the hood and see if the clutch slave cylinder moves when the clutch is pressed. Slave cylinder is on front side of engine on pax side.
letsclique
Jun 18, 2016 04:29 PM
ekg98
Dec 20, 2013 10:20 AM
d0n
Feb 4, 2013 08:45 AM
Andrewjen
Apr 26, 2012 07:47 PM
Will.bartlett
Feb 27, 2010 08:44 PM
