Adding oil to torque converter
Old Aug 6, 2014 | 03:21 PM
moey's Avatar
Default Adding oil to torque converter
Im in the process of replacing my transmission on a 2007 4 cylinder. I picked up a transmission and torque converter at a junk yard. The torque converter has no fluid in it or not much. How do you add fluid to it? Am I blind???
Id like to add some to it rather then start it up dry I know it will get pumped in there.
Old Aug 6, 2014 | 04:16 PM
ATF is pumped in by internal pump. You could pull fuel pump fuse and turn engine over to prefill torque converter. No way to know if successful.
I checked Honda Shop Manual for your vehicle and did not see any discussion of pre-filling the torque converter.
You should get a shop manual to guide your work. An emanual from automanualsource.com is only $22.
Old Aug 7, 2014 | 11:56 AM
moey's Avatar
Correct there is no mention of prefilling it in the Helm's manual.
Cant be to good to start up dry though.
Old Aug 7, 2014 | 12:23 PM
Only support I can offer is the flow rate is relatively high, perhaps 4-6 gpm, so it will only take a few secs to fill the torque converter. No parts touch in torque converter; stator or rotor. Only bearings are issue, and there are many bearings in the trans that depend on oil tranpsort.
Filling of torque converter must also happen when AT is factory assembled and installed.
I think you'll be fine, but turning engine over for 15-30 secs w/ starter may be prudent.
Old Aug 9, 2014 | 04:34 PM
moey's Avatar
Turns out you can just pour it in the shaft of the torque converter. Realized when I pulled it off the transmission and saw the O-ring which stops it from leaking. Added about 1/2 quart to give me a warm fuzzy.
Old Aug 9, 2014 | 06:53 PM
Let forum know how the startup and operation goes when completed.
central34
Mar 16, 2011 07:27 PM
Vishnu
Feb 18, 2007 01:36 PM
sssexy70
Feb 3, 2007 03:50 PM
huzzsaba
Dec 6, 2006 09:41 PM
absolutalchemy
Oct 16, 2006 02:29 AM
