advice on A/C repairs for Honda Accord 2003 EX
Old Jun 28, 2011 | 10:25 AM
atxheel's Avatar
Default advice on A/C repairs for Honda Accord 2003 EX
A couple weeks ago the A/C starts to go during stop/go traffic so I took it to the dealership this past weekend (I'm by no means a car person, the most work I've done on a car before is to install an alternator). They say it would cost $507 to have them repair the service valve which is leaking freon and $553 for cooling fan motor replace. Or both could be done for about $750. I plan on finding a reputable A/C specialist in the area to give a second opinion this weekend.
With the summer heat (Houston), I'm aware something needs to get sdone before the car overheats. After taking it to the dealership, it's now worse than before as there is absolutely NO cool air coming out.
Regardless of the inordinate cost at the dealership, I'm just looking for some technical advice as to whether either of these could be put off without risking further additional problems or if there is any general advice on how to deal with this.
Thanks
Old Jun 28, 2011 | 11:51 AM
As long as you disable AC (turn OFF), the car can be driven. I would avoid prolonged idle as much as possible, but I think you'll be OK as long as AC is off.
My sympathies as I drive in Houston also, and it's been brutal lately; consistent high humidity and temps.
I agree a 2nd opinion on work is indicated. Check w/ AC specialist shops for quotes on this service work.
Old Jun 28, 2011 | 12:46 PM
atxheel's Avatar
its definitely brutal these days. thanks TexasHonda for your reply.
Old Jun 28, 2011 | 01:16 PM
If you can change an alternator, then the cooling fan motor is something that you can change yourself.
Get a second opinion on the work that needs to be done.
JonJon13926
Mar 22, 2013 07:57 PM
hondamartin
Jan 9, 2013 05:10 PM
RobinsonRicer
Oct 29, 2012 12:21 PM
thomasoc
Sep 10, 2009 05:19 PM
honda123
Nov 13, 2006 02:08 PM
