After Market Timing Belt kits
Old May 25, 2011 | 07:25 PM
It can't hurt, but if you heat it will burn and smoke.
A decent set of deep impact sockets can be obtained from Harbor Freight for very reasonable price.
Old May 25, 2011 | 07:47 PM
Not sure if you need the whole set, compare the price of just the 19mm impact to the set...the mounts should come off without needing impact sockets. On the last 3rd gen (no holder for the crank), I had to go to a local shop and get "the guy" to hit it with his impact/compressor to get it loose...I asked how much and he told me not to worry (I buy my tires there) but I slipped him $10 anyway.
Peronally I use Gates products. They offer two kits TCK and TCKWP, the TCK is just the belts and tensioner(s) and the TCKWP comes with a water pump. Up until recently I was not sure where or who made the pump in their kit so I just used the TCK and got the pump from another source, after a recent meeting with them I now know "where it comes from" and will get the TCKWP for the next adventure on one of the Honda's...looks like that will be the '07....oh joy a V6, TX might be hitting you up for advise (your MDX adventure)....and don't forget the seals.
Old May 26, 2011 | 10:07 PM
ChicagoBob123's Avatar
I cant say thanks enough. Resources have been stretched thin these days so I have returned to DIY for any auto repair. This weekend I have brakes lined up for my girls car and tie rod ends for my old van. In about 4 weeks ( aka 2 pay checks) I will give the timing belt and seals a go. Does anyone know of a resource for the tool to install the seals. It looks like a screw and bolt with an external plastic plug that pushes the seal into place properly. I think I will need it for the Cam Seal.
Thanks,
Old May 26, 2011 | 11:05 PM
When you go to do the timing belt, do the crank bolt first.
Old Jun 4, 2011 | 07:53 PM
Most folks manage to install seals w/ homemade press rigs. Board and pry bar, PVC fittings/pipe, etc.
I suggest inspecting the seals and not replacing unless they show signs of leakage or weeping oil. They are not a maintenance item, and you might create a leak where none presently exists.
Old Jun 5, 2011 | 03:08 PM
Red face
Sadly my seals leak.. I also have a leaking oil pan gasket according to the dealer. My hope is after all this the oil leaks cease to be a problem.
Old Jun 6, 2011 | 06:45 PM
  #17
Again, if you are not sure, call around for a place that rents a seal installer tool/set...most of those place refund the full amount once you bring it back.
hugebob
Jul 26, 2011 02:10 AM
wunderbra
Jul 14, 2010 08:42 AM
pwrhouss
Jul 30, 2009 07:17 AM
Tony1M
Apr 1, 2007 05:42 PM
fperezal
Sep 29, 2005 09:29 PM
