air cond filter change
Old Mar 30, 2009 | 08:10 AM
I think the filter is actually upstream of both AC & heater. But YES, it's a little bit of a pain. Beginning in 2003 that filter is REALLY easy to change.
Old Mar 30, 2009 | 01:00 PM
Sweagle02's Avatar
Changed my filters on the '02 yesterday and it was really a pain especially as a first timer but it seems like it will get easier with time. I swear the folks designing the 6th gens were drunk when they decided the placement for these filters!
Old Mar 30, 2009 | 03:49 PM
I bet the filter was a late change, so they didn't want to re-design the glovebox & make it easier to remove.
Old Mar 30, 2009 | 11:48 PM
Sweagle02's Avatar
That's what I'm sayin too man. They built the whole car and remember these filters at the last moment lol.
Old Apr 6, 2009 | 09:32 PM
lvp0412's Avatar
I bought some "batting" in the sewing section, at WalMart. Cut to fit the tray and "wala" a new air filter! Yes, it catches a lot of crap that would go somewhere else that you don't want it to go. (03 Accord EX-L)
Some train of thought is that the pleated paper, in itself, is resrictive (sp). Some HVAC guys don't like the pleated paper in your furance! They say the blue fiberglass allows more airflow. The WalMart batting is similar to fiberglass. I'm not really worried about the "allergens" or I wouldn't be outside at all. Just stop the leaves and pineneedles.
LVP
Old Apr 6, 2009 | 09:46 PM
Wink
AC filter prevents dirt/debris from entering the evaporator from outside fresh air stream. If this material is not filtered, it may eventually cause serious problems; blocked evaporator drain or foul smelling AC system, or both.
I've repaired two cars that had blocked evaporator drains; 94 Accord EX and 94 Jeep Gr. Cherokee. This repair is actually not difficult on an Accord, but on most US vehicles the entire dashboard must be removed. I would not attempt another dashboard removal after tackling the Jeep Gr. Cherokee blocked evaporator, which was also leaking refrigerant. Hands down worst job ever, a nightmare.
Replacing AC filter every year or so sounds like a good investment for a clean, functional AC system.
Here's your Best Ever Answer from One Who works on them...
Thanks Tex
Old Apr 7, 2009 | 07:15 AM
  #17
Restrictive. Yes. Everything is restrictive, even the grille opening where the air comes in.
But if that restriction doesn't dominate the overall resistance, or the system is designed to operate with that restriction, then it's OK.
If you want to remake the filter like that, more power to you. You seem to understand that you're giving up the ability to filter out fine particulates, like smoke & dust.
UP CAT
Jan 27, 2015 11:35 AM
M5 Jed
Apr 10, 2012 11:11 PM
drtrider145
Jul 10, 2008 10:57 PM
n7plus1
Dec 15, 2007 12:24 AM
72mustang
Apr 9, 2006 05:13 PM
