Air conditioner (AC) comes on when defrost activated
Old Oct 4, 2006 | 01:57 PM
Gooch
Default Air conditioner (AC) comes on when defrost activated
2001 Accord LX 4-door
I've noticed that the air conditioner automatically comes on when the defrost or defrost/below buttons are pressed.
I can turn the air off, but I would rather it not come on in the first place.
Can this be done?
Old Oct 4, 2006 | 09:15 PM
Chiovnidca's Avatar
Default RE: Air conditioner (AC) comes on when defrost activated
ORIGINAL: Gooch
Can this be done?
Nope, it's hard wired to do that.
Old Oct 4, 2006 | 09:37 PM
VsVFR
If it is like the 04 Elements there is a way to do it, but I don't know if you would want to! I found out about it on the Honda element owners club site and it involved turning the key to accessory, and doing some assortment of other odd things, and I'm not sure if you had to do this every time you wanted to turn off the compressor or not. But there probably is a way, talk to someone at a dealership.
Vs
Old Oct 16, 2006 | 01:18 PM
MakoMan's Avatar
It's a good thing that the compressor comes on with defrost. An AC unit is really just a dehumidifier, dry air defogs windows well. Plus it helps keep oil circulating in the AC system even in the winter months which goes a long way in preventig leaks over time.
Old Oct 16, 2006 | 03:32 PM
sir_nasty's Avatar
Just out of curiosity what is your belief of the meaning of the word gooch?
Old Oct 16, 2006 | 04:30 PM
Gooch
Well, MakoMan, I didn't know that running the a/c a bit in winter is good for maintenance. I'll be sure to do that.
I use the defrost vents sometimes because I don't want the hot air blowing in my face or at my feet.
Gooch? It's my nickname from my teenage years, from 'The Gooch', the never-seen bully on the tv show Different Strokes. (I was never a bully. Really.)
Old Oct 16, 2006 | 05:47 PM
sir_nasty's Avatar
Gotcha... That makes sense then.... If you look it up though on www.turdwords.com it comes up as something TOTALLY differnet *LOL*
Old Oct 16, 2006 | 06:01 PM
YeuEmMaiMai's Avatar
there should be an A/C button that you can press to turn off the A/C compressor. You turn on the defroster and then press the A/C button to turn the A/C off.
It is by design that the A/C comes on with the defrost as your a/c actually removes moisture from the air.......
meazz1
Dec 15, 2017 07:35 PM
92EX4D2LO
Nov 8, 2010 05:23 AM
jbraly
Sep 1, 2009 01:26 PM
skeenr
Jan 17, 2007 11:30 PM
jeremiah6120
Apr 16, 2006 03:32 AM
