Air conditioner help
Old Apr 2, 2007 | 09:17 PM
ouchevelles
Default Air conditioner help
Hi all,
I just got a 1994 Honda Accord recently, my first Honda, this winter. I don't know where to ask for help but since things are getting hot now, I need to ask! I had my grandparents look at it for me when I was out of town, and they said the compressor worked. When I was about to buy the car, I didn't check it visually, although when I pressed the A/C button and I felt the idle change so I figured it was fine (although this may be electronically controlled, my other car A/C idle is changed at the carburetor). In retrospect they may have been looking at what I'm guessing is an air pump, closer to the top of the engine.
Anyway, I realized it wasn't really blowing cold, and I tried to put some R-134 in (my dad does A/C work so he has tools for cars as well), but then we realized the compressor wasn't coming on. We're not sure if the compressor is dead or not. I have a couple of questions:
1) Do these compressors have low-pressure switches? How are they reset if so? Our pressures were a little low.
2) On the back of the compressor, there is a little dongle or something that has one red wire coming from the compressor to the plug, and the plug has a lot of wires going back into a main harness. However, the plug itself is not connected to anything. Is this a test plug or something, or does it need to be connected to something for the compressor to work? We didn't see any sort of plug-in for this in sight in reach of the wires, so we're not sure.
I don't have an owners manual and couldn't find a wiring diagram online. Thanks for any help!
Old Apr 2, 2007 | 11:08 PM
hondadude's Avatar
Default RE: Air conditioner help
The wire coming from the compressor clutch goes thru a temp shut off on the top of the compressor and then should go over to the drivers side fan shroud and connect into the harness plug there.
Yes there is a dual [high/low]pressure switch, I'm pretty sure it is on the high side line, passenger side just behind the radiator
Old Apr 3, 2007 | 01:29 AM
deserthonda's Avatar
If you go to our DIY section there is a post ( 5th gen accords 94-97 infos and manuals,, ) go to the link and download what you need ..
meazz1
Dec 15, 2017 07:35 PM
jbraly
Sep 1, 2009 01:26 PM
b4iloveu
Nov 23, 2006 02:10 PM
Gooch
Oct 16, 2006 06:01 PM
jeremiah6120
Apr 16, 2006 03:32 AM
