air conditioning affecting brakes?
Old Jul 7, 2016 | 11:00 AM
ugeely's Avatar
Default air conditioning affecting brakes?
Why do i loose a lot of pedal when I turn on the air in my 96 accord 4 cyl. 5 speed ? The higher i turn up the fan the worse it gets. It gets downright scary with fan on high. I read somewhere that it's because a sensor pics up the idle when the compressor kicks in therefore pushing the car when in gear... like stepping on the brake and gas at the same time making it "seem" like the brakes are failing a bit. Well there's no "seem" to it..they don't work near as good. Don't know, but the wife won't drive it, and i'm leary of it to .
Anyone have a idea or have the same problem ?
Old Jul 7, 2016 | 09:16 PM
The two shouldn't be related. Can you give us more detail about what is happening with the brake pedal?
Old Jul 8, 2016 | 07:37 AM
ugeely's Avatar
Default air n brakes
Thank you for reply's. The pedal goes almost to the floor and barely slows down the car...i had to do a quick downshift to make a turnoff the other day. Sounds crazy but the higher the fan is when the air's on the worse the brakes are.
Old Jul 8, 2016 | 08:52 AM
I had a brake master cylinder failure (95 Integra). Piston was leaking back to the reservoir, the classic situation where the pedal sinks slowly & smoothly to the floor.
Funny thing is it DID seem related to AC being on. I was never able to figure out why that was related. But after I got a new master cylinder, it was all good again.
Old Jul 9, 2016 | 10:44 AM
ugeely's Avatar
Thanks for the info Jim. I will check into it. The AC part is really baffling...makes no sense at all.
shoot22
Feb 2, 2019 05:40 AM
zachyzissou
Feb 15, 2009 11:12 PM
AccordNation
Jan 7, 2009 11:14 AM
pwilkes3
Oct 27, 2007 02:57 AM
fireballer44
Jul 25, 2006 09:51 PM
