Air Conditioning System Leak
Old Jul 9, 2007 | 01:46 PM
sbclemens's Avatar
Default Air Conditioning System Leak
I have finished replacing the entire a/c system (except hoses and electronics). I pumped the system down but discovered that there is a leak or leaks some where in the system. It only takes about 10 seconds for the system to leak from about 26 in Hg vacuum to atmosphere.
If I pressurize the system with about 50 psi of dry air from my air compressor to check for leaks, will I damage the system?
Old Jul 9, 2007 | 01:48 PM
sir_nasty's Avatar
Default RE: Air Conditioning System Leak
get an a/c refill kit with the dye in it...
Old Jul 9, 2007 | 03:36 PM
sbclemens's Avatar
The system is completely dry, I haven't even added oil yet. To use dye, I would have to charge the system and I think the leak(s) may be to large that I could damage the compressor.
Old Jul 9, 2007 | 06:45 PM
hondadude's Avatar
No problem at al to put 50 PSI on the A/C system, then you can use a spray bottle of soapy water to go leak hunting. [sm=goodidea.gif]
Old Jul 9, 2007 | 07:26 PM
Such a large leak suggests you may have assembled one of the connections w/ a bad oring or damaged the oring during installation. You should be able to introduce adequate charge for leak detection by pulling vacuum and charging into the vacuum. Charge w/ dead cold engine at night and heat the refrigerant w/ hot water to force as much as possible into the system w/o compressor running. Refrigerant will flow as long as system temp is < refrigerant reservoir temp.
You should be able to hear the leak. Get a young person w/ good ears to listen when/where it's quiet.
shoot22
Feb 2, 2019 05:40 AM
iabbott75
Aug 17, 2006 04:59 PM
sbclemens
Aug 6, 2006 09:42 PM
Thunderhead
Aug 6, 2006 03:22 PM
fireballer44
Jul 25, 2006 09:51 PM
