air fuel gauge help
1997 Accord EX VTEC .. I installed a AFR gauge and got a good ground and a direct connection to the white wire of the pre cat 02 sensor ... however the gauge from Autometer constantly sweeps lean to rich, it does stay at rich during hard acceleration. And sometimes while just cruising it dips to very lean and the light will even go out until the gas is applied. I have no idea if its just a bad sensor or bad gauge .. anyone have any ideas???
I would say that everything is normal. The gauge tends to bounce around a lot, especially with the stock o2 sensors. When you take your foot off the gas and it goes really lean, that's fine too. Now if you had it mashed and it did that... ouch
In the end if you plan on using that gauge to tune, you'll want to go with a wideband sensor. Much more accurate.
ORIGINAL: absolutalchemy
pirulino23
Nov 10, 2010 06:18 PM
