Airbox screw
Old Jun 3, 2011 | 09:57 PM
LinguiniPenguini's Avatar
Default Airbox screw
Hey there!
I was installing a K&N lifetime filter tonight and when I was replacing the Airbox screws one of them decided to snap, so now I'm stuck and don't know where to get a replacement. Any suggestions? I drive a 2007 Accord SE with a 2.4 K24a8 4cyl.
Old Jun 3, 2011 | 10:05 PM
The honda dealership would be the easiest place. They can't be too expensive.
I put a bit of anti-seize on the threads when I install them, because I had the same thing happen. They get corroded in there.
Old Jun 6, 2011 | 02:17 PM
Can I take the screws out and use like a zip-tie or something to hold it closed until I get a chance to get new screws?
Old Jun 6, 2011 | 02:47 PM
If you have three working screws, then they should hold the top of the air box and make a seal on the air filter.
You can put a zip tie around it with the other bolts installed if you are really worried.
rayo725
Jan 18, 2012 05:58 PM
jonnydaub101
Apr 22, 2009 02:48 PM
dforbrich
Jan 25, 2009 02:28 PM
SandMan
Aug 20, 2007 03:34 PM
2000LXV6
Nov 19, 2005 12:45 AM
