Alignment require after axle change?
Old Sep 1, 2009 | 02:49 PM
gonefromparker
Default Alignment require after axle change?
I have a 1995 Accord and had the right axle changed. This is my first axle change. Does it require a wheel alignment?
Old Sep 1, 2009 | 03:27 PM
mcnoople's Avatar
Assuming the job was done right you don't have to do an alignment following an axle swap. The only exception would be if lots of extra parts were removed, but you would have to go way out of your way to remove something that would affect alignment.
Old Sep 1, 2009 | 03:36 PM
Lightbulb Hi McNoople
Would you actually check that out with your front end tech at the dealership you work st...I have that feeling that it would need an alignment..In changeing my own CV's I had the car re-aligned..Please check that out for us..
Thank You !
Old Sep 1, 2009 | 04:44 PM
finch13's Avatar
Shouldn't need one, all parts affecting the alignment are staying the same.
Old Sep 1, 2009 | 05:11 PM
If the balljoints were separated at their tapered pins, and nothing else removed, then OK. If the inboard pivots of either control arms were moved, then you probably need an alignment.
Scar_cle
Oct 19, 2012 06:50 PM
KincaidChance
May 3, 2011 01:13 AM
chris h
Apr 3, 2011 10:01 AM
Tomsaccord
Feb 14, 2007 01:27 PM
nixalot
Jan 25, 2007 02:02 PM
