Allignment/Suspension problems
Old Jan 24, 2010 | 07:33 PM
Chr1s46536's Avatar
Default Allignment/Suspension problems
So i've got a serious negative camber problem in the front, the insides of my tires are completely bald and the outsides have a ton of tread. I was reading that since the camber isn't adjustable that there must be another problem causing this i assume with the suspension.
I was wondering if you guys knew of any typical suspension problems that would cause some serious negative camber. Ive owned the car for a year and about 5 months ago i noticed the ride got much rougher, and going over bumps i heard a clunking noise now. I was thinking blown struts or bushings ro something but i dont know too much about these cars so im not sure of what kinds of problems they get.
The car is a 2000 LX 4 cyl Vtec with 97,000 miles.
Old Jan 24, 2010 | 08:23 PM
kris_loehr's Avatar
Toe can wear the inside and outside of the tire also and it looks pretty much the same as chamber. I would suggest inspecting the suspension and getting an alignment check. If it was from an accident it is usually just be one side depending on what they hit.
Old Jan 24, 2010 | 10:52 PM
Chr1s46536's Avatar
well i know the car has never been in an accident and the wear is exactly the same on both sides
Old Jan 24, 2010 | 11:37 PM
kris_loehr's Avatar
The last set of tires I replaced on my 1995 Accord looked like that and it was a toe problem but you won’t know until it is checked. Do the wheels look to have negative camber if you look at them from the front of your car?
Codywalker13
Feb 16, 2014 10:53 AM
bustum
Aug 27, 2007 06:38 PM
htownfanatic
Jun 22, 2007 12:11 AM
KimberlyC
Apr 16, 2006 11:51 AM
George Knighton
Jan 11, 2006 08:49 PM
