Annoying lights( need help)
Old Jul 9, 2009 | 06:44 AM
Kedar
Unhappy Annoying lights( need help)
I have a 98 Honda Accord (manual Vtec) and I noticed that my battery, brake and door indecator lights up on the dash board. I went to Autozone to check if my battery and alternator was O.K. and they said there is no problem. One of the associates said that the electrical connector to the Alternator might need cleaning, so i purchance a connetor cleaner. It worked for at lest 2-3 weeks this morning it started back up. I was wondering if someone else had the same problem and how they dealt with with it?
Last edited by Kedar; Jul 9, 2009 at 06:46 AM. Reason: forgot the model of my car.
Old Jul 9, 2009 | 09:28 AM
Welcome!
Sometimes that can be caused by ground problems, especially with different things that aren't supposed to be related.
I'm gonna move this to General Tech where you probably get better answers.
Old Jul 10, 2009 | 09:28 AM
00AccordLX5spd's Avatar
Registered User
Try cleaning all of the connections, including where it connects to ground. Trace the negative battery cable and see if there is a connection problem on the end opposite the batery.
Old Jul 10, 2009 | 09:56 AM
Jon, from your 2000 do you know where there's a cluster of ground wires screwed onto some metal back in the dashboard? Maybe near one of the fuseboxes? I never had to remove the instrument cluster when I had a 1998, so I don't know where to look.
onequickevo
May 13, 2013 12:29 AM
musicmaniac
May 26, 2011 01:32 AM
Patrick
Oct 5, 2008 04:06 PM
thunder_x
Oct 22, 2007 04:35 PM
chibiko
Mar 19, 2007 04:03 PM
