Another power steering problem
Old Oct 15, 2010 | 12:19 PM
denning's Avatar
Default Another power steering problem
The car is a 1999 1.85 VTech Honda Accord (European not American).
A couple of months back I was stuck in a contra-flo when i noticed a whining noise. When I finally managed to find a place to pull over about 2 hours later there was fluid sprayed out of the resovoir, the fluid was foaming over and the noise sounded like it was soming from the pump. Nipped off to Halfords, got a bottle of fluid to top it up with, and drove home (as I was in Scotland this was about 250 miles). Kept an eye on the fluid level regularly on the way home. However I then discovered that Honda required specific fluid (from this very forum).
Following the advice I read on here I purged the system and refilled with fresh honda fluid, ran it for a couple of days then repeated. However the whine just kept getting worse as did the foaming. I bit the bullet, replaced the pump (bearings felt shot compared to the new one). Was fine for a couple of weeks. Then the whine returned as did the foaming. The fluid meanwhile has gone so dark its like a bad pint of guiness.
Again foloowing advice from this forum I replaced the O ring on the pump end of the hose that goes to the steering rack. Soaked it in fluid for ten minutes then bolted it down fairly firmly, but didn't overtighten.
Now the car sounds as bad as it ever has. It is not currently foaming over though it is still foaming. The foaming tells me air is being sucked in. The fluid apparently darkens when it absorbs water vapor from the air. Air being sucked in would accelerate this I believe. What I cannot figure out is where the air could be being sucked in from.
Please help. I am at my wit's end with the thing...
Old Oct 15, 2010 | 09:01 PM
kris_loehr's Avatar
You are going to need to clean up the PS components and look for leaks.
Old Oct 16, 2010 | 08:13 AM
Foaming is caused by air being pulled into the PS fluid from the suction side (reservoir to pump). There may not be an external leak while operating, although w/ engine off pressures may equalize and fluid could leak. Look carefully along the suction path for evidence of damage to hose or connections.
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
radar78
Jul 15, 2012 07:56 PM
HondaAccordKid
Oct 28, 2010 11:32 AM
silver03
Dec 27, 2007 07:31 PM
