Automatic tranny question
Old Aug 3, 2011 | 01:48 PM
mgroeger's Avatar
Default Automatic tranny question
I have a 2008 accord coupe, 4 cyl with 50k miles on it. Honda trannies make me nervous so I def want to change the fluid in it now since we just bought it certified from a dealer but have no idea if the tranny has ever been serviced.
The fluid still looks red and does not smell burnt.
I was thinking of doing the old...
drain 3 qts, fill.
run car,
drain 3 qts fill.
run car
drain 3 qts fill.
In theory this changes out about 80% of the fluid. I also thought about going to a trusted garage and having a machine do a complete flush with BG synthetic fluid. I've heard good things about BG and the guy told me the BG machine has the proper hose fittings so as not to neck down the hose and cause undo pressure on the tranny.
I also heard WYNN machines are "passive" flushers in that they use teh power of the trans pump to do all the work.
Is one better than the other? Can I safely use BG synthetic fluid in the Honda tranny?
Old Aug 3, 2011 | 02:02 PM
Check your owner's manual to find the maintenance schedule on your accord. I would not use any flushing machine on the transmission. Also, stick with Honda ATF.
Old Aug 3, 2011 | 07:04 PM
If fluid looks good, I think a drain/replace is fine. Suggest sticking w/ Honda ATF.
Old Aug 3, 2011 | 07:19 PM
g22cd5's Avatar
Supper Moderator
DON'T POWER FLUSH!!!!!!
ONLY DRAIN AND FILL with Honda ATF
Old Aug 3, 2011 | 07:57 PM
EXV6NIGHTHAWK's Avatar
A machine that doesn't push the fluid through, and only uses the transmission's own flow sounds good, but I would stick with Honda fluid. They have a new fluid (DW-1).
swingkid50
May 20, 2012 09:29 PM
Madmax3040
Jan 27, 2008 10:41 PM
Ronnie101
Jun 21, 2007 09:44 PM
jp28
Mar 31, 2006 10:05 PM
Nitro1968
Jan 9, 2006 09:50 PM
