Bad Ball Joints Probably
Old Jul 30, 2011 | 11:30 PM
ExpLo's Avatar
Default Bad Ball Joints Probably
Whenever I make right turns, I hear this scraping sound on the right side of my car. I think the ball joints are going bad. Does anybody know how to check to see if they're bad?
Old Jul 31, 2011 | 12:01 AM
bigpat's Avatar
Almost A Senior Member
To check for worn or broken ball joints, you need to jack up the front of the car so that the front wheels are off the ground 6" or so. Place a 2x4 or large prybar under the tire and pry it up... If you notice some play or slop in the ball joint or lower control arm, you need to replace the ball joints. It really helps to have a second person to do the prying while you are looking for wear. NOTE: DO NOT INSPECT FROM UNDER THE CAR WHILE IT IS ON THE JACK....YOU CAN GET KILLED IF THE CAR FALLS OFF THE JACK !! The safest thing to do is to take it to an alignment shop for a free courtesy/safety inspection.
Old Jul 31, 2011 | 07:02 AM
piggylover1985's Avatar
Also check the wheel bearing and brake shield.
Old Jul 31, 2011 | 10:40 AM
hobieslug45's Avatar
ball joints are clunks .wheel bearings are roars and brake shields are scrapes. but not all ways
soba_03
May 15, 2014 04:50 AM
97 cd7
Nov 8, 2012 12:17 PM
MALSR
Mar 26, 2007 04:31 PM
brownstreak
Jan 17, 2006 06:14 PM
