Bad idle !!!HELP!!!
Old Feb 18, 2012 | 06:59 PM
bostongrun's Avatar
Default Bad idle !!!HELP!!!
I have a 99 EX, V6 Coupe 120K, Auto with a bad idle. It drops too low and sometimes kills at stop signs. It has no problem when stone cold but starts having issues at operating temp especially when lugging in freeway rush hour stop and go.
I suspect that the msifires occurs when the idle goes too low triggering the codes. It runs perfect when the throttle is open.
Here is what I have done
Valve adjustment 10k ago
Removed upper plenum and cleaned and drilled out the port that clogs
Cleaned the egr valve and passage
Checked the idle control valve by unplugging it (it works)
New plugs, wires, cap, rotor, air filter, throttle body gasket
Two Seafoam Treatments
Anyone got any ideas?
Old Feb 19, 2012 | 08:26 AM
What is the base idle at?
Old Feb 19, 2012 | 10:17 AM
bostongrun's Avatar
Default Finally!!!! Solved the bad idle issue!!!
As you may have seen I have made a half dozen posts regarding an up until now unsolvable rough idle problem on a 99 Accord EX V6. I cleaned the mainfold port, EGR valve & ports, new plugs, wires, cap, rotor, and just about everything else.
I noticed that when I removed the throttle body that no coolant came out of the IAT lines. I checked thle recovery tank and it was a little low but not to the point where it was a concern. I removed the radiator cap with the motor running and I was able to add 2/3 of a gallon!! I let the motor get to temp with the cap off and it burped huge air bubbles. I couldnt find a bleeder screw anywhere so I just burped it by squeezing the upper hose.
For some reason these cars have a coolant line running to the IAT valve. I am thinking the purpose is to warm the sensor so when at temp it restiricts air flow to reflect a leaner idle mixture when hot versus richer a t start up.
My logic is if there is air in the system not enough coolant flows to sensor to make it effective?
Any ideas on this?
Old Feb 19, 2012 | 12:30 PM
Yes, there's supposed to be coolant flowing there to warm up the FITV and IACV.
Air pockets in the cooling system are well-known to confuse the idle-control system.
giulio76
Dec 29, 2012 11:16 AM
Jesus Pickles
Apr 29, 2012 08:44 AM
NEPORTLANDMV
Apr 27, 2012 12:21 AM
MessAround
Sep 3, 2011 05:44 PM
giffin
Feb 17, 2007 09:50 PM
