Bad low fuel light
Old Oct 30, 2021 | 03:34 PM
Ryan2000accorddx's Avatar
Default Bad low fuel light
My 2000 Honda Accord dx has a bad low fuel light and I can't find anywhere the size I need to replace it. And help or suggestions?
Old Oct 31, 2021 | 10:49 AM
Have you verified the bulb is bad vs the sensor on top of the gas tank not working properly?
Old Oct 31, 2021 | 11:48 AM
Actually no I didn't. I don't exactly know how to do that, I just assumed it was bad cause it was a hazy black in the bulb when I was changing the others in my cluster. Any info on how I would check the censor?
Old Oct 31, 2021 | 03:52 PM
Remove the cover for your spare tire. Near the back seat in the trunk, remove the access panel to the fuel gauge sending unit. Unplug the 5-pin connector. Jump the light green/red strip wire to ground with a piece of wire. See if the light turns on with the key in the II position. Also jump the ltgrn/red wire to the black wire on the connector and see if the low fuel light turns on (this test the black wire in your trunk).
Old Nov 30, 2021 | 11:04 AM
So if I confirm the light is good and the sensor is bad. What do I need to replace in my 2000 Honda Accord dx 2.3l 4cy
Old Nov 30, 2021 | 06:45 PM
The whole sending unit under that cover in the trunk would need replaced. I'm not sure you can fix just what is broken on the sending unit.
Stevek66
Aug 15, 2019 09:29 PM
Pajamarama
Aug 27, 2012 06:12 PM
kuhlag
Jul 11, 2010 01:23 PM
petmos
Aug 8, 2007 12:51 AM
mrmookie123
Jul 21, 2007 08:54 PM
