bad neutral safety switch?
Old Jul 1, 2012 | 11:30 AM
Steven Perron's Avatar
This may or may not go back to a problem due to the "water" thread.
  • I had previously suggested cleaning the battery ground wire contact areas due to the water (e.g., remove bolts holding battery ground cable, clean chassis ground area with sand paper and wire connector, etc.). In one of the attached pictures, it shows the battery ground wire connectors to the car's chassis. The ECU (car's computer) ground is G101 (shown in another attached pic.); this ground connector to the ECU is also relying on the battery ground wire connections at the other parts of the chassis. You may want to clean the battery ground wire connections, battery terminal posts, and possibly ground G101; and ensure all these connections are tight.
  • a main relay problem. The car not starting immediately could also be a main relay problem. See these links:
How the Main Relay works
Honda Acura Starting Problems Repair Guide, Main Relay Locations
This other link shows the main relay location for a V6 in your model year; but, it should be similar for your L4 model. I also attached a pic. showing the location.
DIY, Replacing Main Relay (AV6) - V6 Performance.net Forums
  • or even something else.
very educational, if im reading the flowchart right, my main relay is ok. this is a good read tho, hopefully i have a mechanic coming by the house this week to take a look at it for me, thank you so much
Old Jul 1, 2012 | 11:41 AM
The main relay possibly shouldn't be ruled out yet. See this excerpt screenshot from the 2nd link I posted.
The main relay solder joints can be visually inspected for hairline cracks and cold solder joints; and re-touched with a soldering iron and solder.
Old Jul 1, 2012 | 11:50 AM
ill check it out when the weather cool down later tonight, thank you much
Old Jul 1, 2012 | 12:06 PM
I asked this before, but you didnt answer. How many miles are on the spark plugs? What brand did you use?
Old Jul 1, 2012 | 12:08 PM
honestly, i couldnt tell you the miles on the plugs, they are the ones i got with the car, i bought the car in feb of 2011 with about 150k miles on it. i assume they are OEM
Old Jul 1, 2012 | 12:53 PM
I have read about similar starting problems using the incorrect plugs.
Your car take NGK ZFR5F-11 spark plugs and most parts stores carry them. They are about $2 a plug. They are due to be replaced every 30K miles.
I would definitely change the spark plugs. This may be a $6-$8 fix.
Old Jul 1, 2012 | 01:05 PM
  #17
im gonna change the plugs either way, since i assume they are old, i have put at least 30k miles on them myself since we got the car. the starting problem was never an issue until that rain storm that blew through here.
Old Jul 1, 2012 | 01:12 PM
  #18
30K is the recommended spark plug change interval for your car, along with air filter, etc.
louisvilleslugger
Oct 4, 2011 09:45 AM
916dave
Sep 21, 2011 10:12 PM
pwcfan
Dec 10, 2008 09:31 AM
rflail
Jun 14, 2008 01:31 PM
inhot
Jun 7, 2008 07:23 PM
