Balance Shaft Belt Removal
Old Sep 7, 2008 | 10:01 AM
Vcong
Default Balance Shaft Belt Removal
I've just recently changed Timing Belt and Balance Shaft Belt on my Accord 96 VTEC after the Balance Belt snapped and made the Timing Belt jump gears. All exhaust valves were bent and had all replaced. Initially, there was loud whinning when engine was run after belt replacement. The belts were inspected and Balance belt was noted to be too tight so it was re-adjusted. Now the whinning is gone but I am not totally satisfied with the sound around the timing belt area. My thought is that the Balance Shaft is not turning smoothly. Could I just remove the Balance Shaft Belt altogether for fear it might snap again if I let it as it is now? BTW, I just had both Timing Belt and Balance Shaft Belt replaced a year ago at 80T kms and the replacement Balancer Belt snapped at 92T kms.
Old Sep 8, 2008 | 02:05 PM
brayner's Avatar
Default RE: Balance Shaft Belt Removal
it's my understanding that the balance shaft is there to remove vibration
Old Sep 8, 2008 | 05:42 PM
hondadude's Avatar
You can remove the counter balance belt, but you will feel like you are riding in a helicopter.
Remember those hueys they used to fly us out to the missle sites with?
Stock up on motor mounts.
Old Sep 9, 2008 | 11:15 AM
deserthonda's Avatar
ORIGINAL: Vcong
that sounds odd,belt gone after 12k miles .. either the shop did something wrong when doing the job or they used a very, very cheap belt,, bal belts should last at least 70-90k miles if not more ..and since it has only been 12k miles, is it under warranty ?? most shops warranty their work at least 1 year or 12k miles ,, I would inquire about that with the shop that did the job last year
snicrep
Oct 24, 2012 09:53 AM
nrmskate
May 16, 2012 04:27 PM
irhunter
Mar 13, 2010 12:04 PM
kris_loehr
Nov 26, 2008 05:52 PM
mrwigglezdj
Dec 23, 2007 10:33 PM
