Battery,brake lights came on
Old Feb 24, 2013 | 07:51 PM
ed1404's Avatar
Default Battery,brake lights came on
Hi Guys, this is my second thread, my battery,brake and doors open lights came on on my dash while i was driving, could this be my alternator. i appreciate any help. Thanks Ed.
Old Feb 24, 2013 | 08:05 PM
firefighter44's Avatar
Almost A Senior Member
Cant be completely sure with out running my own personal diagnostics but it could be possible, i have a 96 ex and when i had an issue with my alternator going bad i found that my battery and brake light came on in the dash and also with mine my tach stopped working. Seems that that a bad alternator will cause several strange symptoms with the older accords. If you have a volt meter or multimeter you can perform a voltage output test on the alt by connecting the positive lead to the alt and the negative to the negative of the battery and that will tell you the voltage output of the alt which should be somewhere near 14 volts.
Old Feb 25, 2013 | 08:20 AM
Dr. Drivability's Avatar
yup, more than likely. abnormal voltage situations can cause all kinds of havoc on the dash lights and other circuits.
Old Apr 1, 2022 | 07:37 PM
Anurseryb's Avatar
I know this is an old thread but recently my 2001 accord ex 5 speed starting showing the battery, brake and all doors lights. i went to auto zone and o reillys and had the alternator/ battery checked. everything was fine checked by both places.. i then bought a new battery because mine was 7 years old and starting to bulge on the side. still had the lights on. the lights come and go here and there.. i then tightened my alternator belt and test drove it.. lights went away. hopefully it stays off! hopes this helps!
Brandon McCullough
Feb 22, 2019 06:54 PM
Jon Moore
Oct 6, 2017 06:57 PM
Jfon101231
Sep 3, 2015 12:44 PM
Erin Roland-Spahr
Jul 21, 2014 08:43 PM
BuddyHopkins
Jan 13, 2008 12:22 AM
