91 Accord SE Oil Cooler Line
Old Mar 27, 2022 | 04:39 PM
Sarisataka's Avatar
Default 91 Accord SE Oil Cooler Line
Hey all, I just recently purchased a 91 accord se and it had a leak in one of the oil cooler hoses. I have the oil cooler removed and plan on replacing both the hoses while I have it off, but noticed how close the fitting is to the block. This is where the leak was at on the old hose I'm assuming due to being pinched in such a tight spot. Does anyone have a suggestion on a different way to attach the new hose via an adapter or anything so the new hose won't eventually have the same problem.
Thanks
Old Mar 27, 2022 | 06:50 PM
Merged your two posts, because they are essentially the same post.
Is that large main line a rubber or metal hose/pipe?
Old Mar 27, 2022 | 06:58 PM
Sarisataka's Avatar
Thanks, I didn't mean to double post.
It's metal.
Old Mar 27, 2022 | 07:14 PM
The water coolant pipe may or may not have been removed/replaced before; then may not have been installed/reinstalled with as much clearance for the oil cooler hose to connect at the pipe nipple. The car is 31 years old, if you try to rotate the water coolant pipe for more clearance, depending on if there is corrosion, etc., it may end up breaking.
Easier and less chance of breaking the coolant pipe by just replacing the hose with the proper type hose, as is. It probably can last quite a while with just a new hose.
Old Mar 28, 2022 | 05:57 PM
Sarisataka's Avatar
Thanks for the reply, ya I was thinking about just putting it back on that way and hope for the best lol.
Old Mar 28, 2022 | 06:20 PM
Hoses deteriorate quick if they get oil on it. If oil drips from somewhere else onto the hose, that can also cause the hose to fail.
Old Apr 3, 2022 | 05:57 PM
Sarisataka's Avatar
The hoses came in yesterday and it's all put back together. Everything seems to be fine and no leaks.
Thanks for the info and suggestion.
Noob_ Mechanic
Jul 21, 2020 05:34 PM
'89 Accord LX
Oct 21, 2017 06:56 AM
Whooosah
Sep 29, 2012 11:58 AM
Sep 23, 2007 09:28 AM
sdfollmer
Nov 13, 2005 09:11 PM
