Battery Ground is SO Important
Old Jul 14, 2018 | 11:48 AM
Dixie Joe's Avatar
Default Battery Ground is SO Important
My car 2001 Accord V6, 180K miles. I replaced the battery and alternator 6 months ago. The SRS lights have been working intermittently for years, plus other electrical maladies. My battery died and alternator output was 13.0V, I had bad transmission shifting. I found out with a volt meter that the battery ground cable was bad to the frame and block. Cleaned the connections and added a new ground strap to the engine block- darn if it didn't fix ALL the electrical problems. I was showing a 1 volt difference from battery negative to block, and a 2 amp resistance (block to battery). Amazing difference- back to 14.5VDC at the battery. Do this first
Old Jul 14, 2018 | 01:27 PM
Welcome to HAF!
This is so true in newer cars. Have to have good stable electric power otherwise all kinds of flaky things can happen.
But I moved this out from the other thread. That was about a 1983 Accord with a carburetor so I think your advice applies more to newer cars.
torrey
Dec 9, 2013 11:22 PM
accords own
Aug 24, 2007 05:43 PM
Foofer
Jan 14, 2007 11:52 PM
Hondamatic
Dec 31, 2005 07:29 PM
Evlampius
May 21, 2005 11:47 PM
