Been searching w/no luck - 96 accord stall with AC on
Old Feb 28, 2013 | 06:39 PM
csk.jfoxx's Avatar
Default Been searching w/no luck - 96 accord stall with AC on
Wassup everyone. Ive been searching the DIY and general section but cant figure it out. Whenever I have my A/C on and I come to a complete stop like at a light Ill stall when I try to accelerate. Any help would be greatly appreciated. Mahalos and thanks
Old Feb 28, 2013 | 06:50 PM
Start with cleaning the TB and IACV....the extra load of the AC comp might be more than a dirty IACV can handle.
Is this an auto or manual car?
Old Mar 2, 2013 | 08:33 PM
csk.jfoxx's Avatar
this is auto and forgot to mention but i did both of those already
Old Mar 3, 2013 | 10:30 AM
And the rest of the tune up items are up to date?
With the AC on, what is the idle rpm? With the AC off what is the idle rpm?
Old Mar 5, 2013 | 04:14 PM
csk.jfoxx's Avatar
everything is up to date. with ac on about 750 and with ac off a lil less. between 700 and 750.
Old Mar 5, 2013 | 07:45 PM
Did you clean IACV inlet screen and valve movement? The valve movement can become clogged and sticky.
What happens when you disconnect IACV? Idle should decline to about 550 +/- 50 rpms.
Old Mar 7, 2013 | 11:02 PM
csk.jfoxx's Avatar
I've cleaned the IACV 2 times and idle drops just like you said. I have no idea what to do
Old Mar 8, 2013 | 05:43 AM
From your description, idle speed is normal when idling, but when coming to a stop w/ AC on, the engine stalls due to AC compressor load.
What happens when not driving and AC load comes on? Does ECU compensate, or does idle rpm depress low also?
Old Mar 8, 2013 | 08:34 AM
Have you set up your base idle? The "base idle" is 550 RPM with the IACV unplugged, SCS connector shorted, and no loads on the engine. Then when you plug the IACV back in, the idle-control system will bring the operating idle up to the 700rpm that everyone expects.
If that is set incorrectly, then the ECU will bring the operating idle back to 700 but the IACV will not be in it's proper "sweet spot" for responsive control of idle. Then it's not able to do a real good job preventing stalls when you drop to idle with the load of the AC compressor.
RA041324
Oct 18, 2023 11:59 PM
corvetteking
Sep 19, 2010 01:36 PM
Gary L
Oct 6, 2008 04:27 PM
texaccord
Jun 3, 2008 04:25 PM
19Accord97
Sep 7, 2006 11:53 PM
