Belt Or Pulley making a squeaking noise
Old Jul 8, 2009 | 01:19 PM
zann121's Avatar
Default Belt Or Pulley making a squeaking noise
Everytime i start the car i hear a a squeaking noise from the belt or pulley.. when i look deeply under the hood i see a pulley wobling. so i think it is lose. could that be the problem and how can i fix this? thanks
Old Jul 8, 2009 | 04:24 PM
lairdylairdy's Avatar
could you post a picture of the pulley? i'm having the same problem right now with the pulley for my a/c compressor. i have a 97 however
also if you look at the thread i have posted earlier in this section JimBlake gave me some suggestions that might help you since it sounds as though you're having the same issue
Old Jul 8, 2009 | 11:17 PM
zann121's Avatar
actually what i noticed now.. the squeaking noise only comes when im not stepping on the clutch. when i let go completely from the clutch and i hear it but when i step on the clutch very lightly the noise goes away? what can be the problem? would i need to replace my clutch?
Old Jul 9, 2009 | 09:09 AM
That sounds like it could be the clutch throw-out bearing. It would be good to pinpoint the location of the noise to be sure. Scrap piece of garden hose makes a good poor-man's stethoscope. Just don't get caught up in the spinning stuff...
A squeaky throw-out bearing can last a long time, so no panic. What happens, is that the T-O bearing has very little load when you don't press the clutch pedal. When you press it just a bit, you press the bearing together a bit better & that makes the noise go away. Often it's a rattling noise rather than squeaking.
Old Jul 9, 2009 | 04:09 PM
zann121's Avatar
so what you think i should do.. when i try to find out where the noise is coming from i cant. its very deeply inside i guess..
Old Jul 9, 2009 | 04:57 PM
Well, you should still deal with the wobbling pulley, regardless of the noise. Which pulley is wobbling? Loosen or remove the belt & see if the pulley is loose. If it's not loose, then the important thing is whether the belt-tracks are straight, or if the wobble is just superficial surfaces.
If the noise goes away after you fix the wobbling pulley, then you can BE HAPPY.
papajimmm
Jul 10, 2012 12:38 PM
mamtsberg
Jul 9, 2010 11:41 AM
elessar78
Dec 17, 2009 07:38 PM
custy
Jan 31, 2009 07:31 AM
accordfan222
Oct 14, 2007 07:19 AM
