Best Jack Stands and Floor Jack locations?
Old Feb 2, 2011 | 12:40 PM
Reggi's-accord's Avatar
Default Best Jack Stand and Floor Jack locations?
I'm getting ready to replace the rear rotors and brakes on my '07 SE. I'm wondering where the best place is to locate the jack stands and my floor jack. I've seen online videos where someone put their jack stands in the spot where the scissor jack would go. My jack stands have a curved saddle so that didn't seem like a good idea without some type of adapter. That same video showed the floor jack located under the tiedown hook near the rear bumper. On my Lexus RX300, I locate the floor jack under a support member about 3' from the bumper. What do you folks do?
Thanks for your help,
Reggi
Old Feb 2, 2011 | 01:37 PM
All the Hondas I've owned use that tie-down hook as the official recommended rear-center jacking point.
95 Integra
98 Accord
03 Accord
07 Civic
So I bet that's the traditional thing for all Hondas. I jack the center then put the stands at the rear-side jacking points.
The tire-changing jack has a shallow V and the metal flange simply sits on that. I just take my stands & put a piece of cardboard between to provide a little protection for the paint & rustproofing.
Old Feb 2, 2011 | 01:45 PM
Here are the jacking points and stand locations (front and rear) for future reference.
Attached Thumbnails Best Jack Stands and Floor Jack locations?-jacking-locations.jpg   Best Jack Stands and Floor Jack locations?-jack-stand-support-points.jpg
Old Feb 2, 2011 | 02:32 PM
Thanks Guys, you are the best!! I'll use those lift points and try the cardboard tip. I wish someone had a notched adapter to fit over the jack stand saddles (to duplicate the way the scissor jack makes contact).
Old Feb 3, 2011 | 04:45 PM
I fashioned some adapters for my jack stands to allow support on ether side of the vertical plate stablizer. Here's what I did:
1) Traced outline of the jackstand support onto 1/2" plywood and cut 4 pieces to fit the jack stand smoothly w/ jigsaw. A band saw would be better if available. Cut pieces are flat on top and complex curve on bottom to fit the jack stand support.
2) Wood glue used to join 2 pieces together into a single ~ 1" thick adapter.
3) Cut a center slot in adapters deep enough to allow the guide plates to penetrate w/o supporting the vehicle. Load is out rocker arm panel either side of the vertical plate.
Adapters have worked well for several years now.
Old Jul 29, 2011 | 05:12 AM
1122union's Avatar
Default Jack adaptor
I used two hockey pucks glued together with a groove cut in the middle.
Old Apr 22, 2012 | 07:49 PM
jkowtko's Avatar
Almost A Senior Member
As referenced above, I would think just a small (6") section of 2x4 with a groove cut in it, would do the trick, no? A nice piece of pine always seems to cushion the load and mold to the sharper features of the jack/stand and jack points.
I've been using sections of 2x4 and 3/4" plywood as needed on both the Honda and Mercedes ... works very well for me.
Old Dec 2, 2012 | 07:26 PM
pugger's Avatar
I don't get it. I've got a smashed finger tip on my right hand from my failure to place jackstands under the rear to try & rotate my tires - fail.
So I looked at that hook, won't that hook bend if I place the cup of the floor jack underneath it ?
I appreciate any suggestions. Thanks.
Old Dec 2, 2012 | 08:02 PM
The tow hook shouldn't bend, I've jacked up Hondas by the tow hook(s) plenty of times without problems. As a precaution, I always place wheel chocks on the opposite end of the car from where I am jacking.
Old Dec 3, 2012 | 02:23 PM
I've never bent a tow hook. It appear to be high strength steel. I always use chocks and set e-brake if lifting front. If lifting rear leave in park.
On front, I sometime support on the anti-sway bar guide plate. This lifts higher and is easier to support w/ a V-shaped jack-stand support. This is not a Honda-approved support point!!
mtill58513
Mar 1, 2013 02:56 PM
letsclique
Dec 28, 2012 05:39 PM
PinkFloridaFlamingos
Dec 10, 2011 07:37 PM
funaccord
Aug 29, 2007 02:08 PM
96hondaaccord
Aug 15, 2006 01:24 PM
