use scissor jack with jack stands
Old Aug 28, 2007 | 01:42 PM
funaccord
Default use scissor jack with jack stands
Hi all,
is it possble to use the scissor jack that comes with the car and use it to place the car on the jack stands?, has anyone tried doing that
Old Aug 28, 2007 | 01:56 PM
00AccordLX5spd's Avatar
Registered User
Default RE: use scissor jack with jack stands
I haven't tried it, but I definitely think it would be possible. It would just be a much bigger PITA than to buy an inexpensive floor jack.
Old Aug 28, 2007 | 02:33 PM
sir_nasty's Avatar
I've done it on more than one occasion. Usually what I do (when a floor jack isn't available) is to block the tires that will still be on the ground, set the e-brake, put the car in gear, then jack up the car and place my stand under one side, jack up the other side and place the stand then release the pressure off the stand by just a little bit and leave the jack still touching the lifting point on the car so if something happens it's an extra failsafe.
Old Aug 28, 2007 | 03:32 PM
falkore24's Avatar
I've done it. It's just not as safe. Also, the scissor jack won't go as high as a floor jack which can add to your aggrivation (re-jacking back and forth adding wood is VERY dangerous, but I've had to do that also -- floor jack lost its seal).
SN, you prefer to put the weight on the jack as opposed to the stand? The jack stand should be able to withstand a lot more weight than the jack. Maybe I'm just misunderstanding you.
Old Aug 28, 2007 | 04:27 PM
sir_nasty's Avatar
It must not have been that clear... I use the jack stand to support the weight of the vehicle but I leave the jack so it's still just barely touching the car (not supporting anything) so if a stand gives out or the car rocks/tips you should still be safe since the jack is still in a raised position...
But no I don't put more weight on the jack than on the stand. good catch though, that's a good thing to clarify
Old Aug 29, 2007 | 12:06 AM
Just be careful&watch what you're doing.You must not create a situation where some part of the load is carried by the jack, making the jackSTAND more prone to topple.
Old Aug 29, 2007 | 10:52 AM
funaccord
so it means that there are really two jack points, one for scissor jack and other for the jack stand otherwise it's not possible to raise the car on the scissor jack and place the jack stand, i do see a spot just beside the point where i used the scissor jack not sure if the one is the other spot (2002 accord LX)
Old Aug 29, 2007 | 02:08 PM
falkore24's Avatar
There are a lot of points under the car that you can support it from. The best place depends on your task. Most things that look well supported are. Be careful and make sure that the car is well balanced, not bumped and supported evenly. Also, the car should have the emergency brake set and either be in gear (manual) or park (auto).
SN: I figured that was what you meant, but it just didn't read right. If a stand gives out, it's most likely that it tipped over. In this case, I would expect the jack to tip as well. I do the same thing, but for a different reason. I leave the jack in place with tension transfered to the stand so that I don't have to crank the jack down only to raise it later to lower the car. I do it mostly out of laziness!!! LOL ..... but I guess there is a bit of added safety.
mtill58513
Mar 1, 2013 02:56 PM
letsclique
Dec 28, 2012 05:39 PM
Reggi's-accord
Dec 3, 2012 02:23 PM
PinkFloridaFlamingos
Dec 10, 2011 07:37 PM
96hondaaccord
Aug 15, 2006 01:24 PM
