Bisimoto Stage 2 cam timing
Old Sep 12, 2014 | 10:57 AM
F22_0529's Avatar
Default Bisimoto Stage 2 cam timing
I have had a F22B1 with a Bisimoto stage 2 cam and gear for a while now and i have been running with straight up timing. It runs and pulls great for just a cam upgrade but i still feel like the timing is off. is there a fairly easy way to figure this out? or does anyone have a similiar set up and if so what is your timing set at?
Old Sep 13, 2014 | 08:12 AM
When checking the timing with a light, what is it reading? Be sure the service connector is jumped when doing this.
Old Sep 14, 2014 | 08:25 AM
F22_0529's Avatar
I checked it with a real old timing light that i had laying around after i put it in awhile ago and it looked a little off, but what do you mean by service connector?
Old Sep 14, 2014 | 10:25 AM
The 96 is OBD-II from the factory....I'm going to guess you have not changed it.
There is the data port behind the ash try and also still the old OBD-I two pin service connector behind the glove box.
Old Sep 14, 2014 | 04:08 PM
F22_0529's Avatar
Ok thought thats what you were talking about just wanted to make sure, il have to buy a new timing light (other one disappeared) and recheck it. I know how to bypass the obd1 connector but not the obd2 one without one of those cel checkers does it matter which one i use?
Old Sep 15, 2014 | 08:02 PM
Best to stick with the ODB-I service connector.......without a scan tool there are ways to do this but since you are lucky enough to have the other option....use it
Sethgreen
Aug 4, 2011 01:58 PM
CH@Dbee
Jul 7, 2009 06:59 PM
live2rice
Dec 30, 2008 10:26 AM
legionofone
Apr 5, 2008 10:39 AM
whitev6penguin
Sep 7, 2006 01:08 AM
