Blown head gasket....AGAIN
Old Feb 23, 2011 | 11:10 AM
Shag Wagon's Avatar
Thats the thing I can't figure out. I don't have any bubbles or extremely tight coolant lines. No bubbling of my coolant reservoir or inside radiator. I am going to check the voltage on the TPS and see what it says.
Old Feb 23, 2011 | 11:42 AM
When I had problems w/ my 94EX, I confirmed my suspicion of head gasket leak (missing on hot start) by pulling plugs (water on 1 plug) and turning engine over (water spary out of spark plug hole).
If you're losing coolant and can't account for it w/ external leaks, then head gasket is likely. Make sure you don't have heater core leaks, heater hose leaks, IACV heater hose leaks, and other small utility coolant lines.
Old Feb 23, 2011 | 07:55 PM
Shag Wagon's Avatar
I switched the MAP sensor for a known good one and set the TPS to .45. None of those worked. It did good today until a couple of hot starts finally got it to sputter and my friend confirmed it. A leak down test this weekend will verify.
jackkuykendall
Sep 18, 2011 08:50 AM
Shag Wagon
Oct 12, 2010 03:37 PM
balaskonis
Apr 28, 2010 04:06 PM
freezerman
Apr 29, 2009 01:03 PM
htownfanatic
Jun 24, 2007 09:54 PM
