Blown Small Lights Fuse
Well, if the wire before some bulb is shorted (bare wire touching metal) then it'll blow even when all bulbs are removed.
Better to unplug parts of the circult and measure resistance to ground. When you find one branch that has nearly zero resistance to ground, then you've narrowed down your search to that branch. It can become a very tedious PITA if the short it hidden somewhere.
No problem. I couldn't figure it out, so I took it to my Grandfather's mechanic. He couldn't figure it out either, so he removed the fuse and replaced it with a in-line circuit breaker. Definitely not the best or recommended solution since it treates the symptom and not the underlying cause, but I've not had any problems with the lights going out since. I've kept an eye on it, though.
Thanks.
Uberpippi
Feb 1, 2013 10:09 PM
linden
Dec 9, 2012 12:09 PM
Klimentiy
Sep 14, 2011 11:46 PM
94, 97, accord, blowing, brightness, controller, dash, fuse, hinda, honda, interior, light, lights, replacement, small
