Brake Issues
Alright I have an issue regarding my brakes. When I am at a stoplight or just in drive for that matter, the brake pedal slowly starts to sink in towards the floor. The brake pads are only a year old and look like they have plenty of life left in them. I recently bled the brakes to try and fix the problem but it didn't solve anything. Wondering if there is a way to get my brakes "stiffer" if that is what you would call it. Thank in advance.
Sounds like failing brake master cylinder. It probably has an internal seal leak, you won't see any external leak of fluid. When the cylinder piston seals go bad, the fluid bypasses the seals and goes back into the reservoir. One of the symptoms would be the brake pedal sinking on hot days.
First, you can do what's called "bench-bleeding" the new master cylinder. Find some tubing that kinda fits the outlet holes, and rig it so it squirts back into the reservoir. Put some fluid in the reservoir and pump it. Fluid will pump around and fill the cylinder properly so now you don't have air bubbles inside the MC.
The MC will have fluid, so installing & hooking up the car's brake tubing can be messy. If you're lucky, you can do that without trapping any air at the tubing connections. But more likely you'll have a little air in there.
Bleeding the brakes is in this thread.
https://www.hondaaccordforum.com/for...g-brakes-3077/
If your car has ABS, you can bleed that system too.
https://www.hondaaccordforum.com/for...systems-31259/
Normally, if you don't bench-bleed the MC, you'll have troubles getting all the air out. It's possible (I've done it), but you might use a couple liters of fluid before all the air is out.
I replaced a MC before I knew anything about bench-bleeding. It was a royal PITA, I still had a soft pedal, and had to run back out to buy another liter of fluid. After getting a ton of fluid without any bubbles, I finally got a few air bubbles then it was OK.
