Brake lights do not work
Old Oct 12, 2008 | 01:18 PM
dbaone
Default Brake lights do not work
Greetings.
The car is an '87 Accord DX hatch. All the lights work except the tail lights when I press the pedal. The bulbs and fuses are good. I even went as far at to replace the switch but they still do not work. I've searched everywhere on the web but nothing has provided an answer.
Old Oct 12, 2008 | 01:32 PM
brayner's Avatar
Default RE: Brake lights do not work
check for signal from brake light switch. check for signal at tail light. if the switch is good it could be wiring
Old Oct 12, 2008 | 01:37 PM
dbaone
I used a test light where the switch connects to the harness and that is getting juice. Now I need to use a test light on the green and white wire on the tail lights? That is the brake light wire correct?
csh217
Apr 30, 2013 09:03 PM
averagespectrum
Mar 2, 2012 05:40 PM
87accord
Mar 16, 2011 08:53 AM
pnoiremix7o7
May 28, 2008 02:41 PM
isxtexas
Dec 8, 2007 11:27 PM
