Brake lights do not work, but they light up
Old Feb 28, 2012 | 10:28 AM
averagespectrum's Avatar
Default Brake lights do not work after battery drain [RESOLVED]
My grandpa drives a 2004 Honda Accord V6 EX.
After an accidental battery drain, we used jumper cables to bring it back up and running.
(1)
But the brake lights do not light up, save the rear windshield and spoiler lights. -- resolved by unplugging & replugging brake light bulbs
If it helps, here are additional issues that arose simultaneously:
(2) Stereo and clock locked up. -- resolved by entering security code
(3) The remote engine starter (third party installation) no longer works.
Old Feb 28, 2012 | 11:07 AM
(1) during locking / unlocking, those aren't the brake lights. Those would be the parking lights.
Old Feb 28, 2012 | 05:23 PM
Thank you for the clarification. I'll make the corrections in the first post.
Old Feb 29, 2012 | 06:40 AM
So...
The center stop light probably uses a different ground than the other brake lights? I'm not sure if the parking light share a ground with the brake lights, but look for an open ground.
Do you get a warning lamp about "brake lights"? If not, then maybe the circuit is open after the point where the center lamp splits off.
Old Feb 29, 2012 | 07:57 PM
Not sure if the 7th is like the 6th gens or not. On the 6th gens, there is a different fuse for the "outer" lights than the high mount.
Attached Thumbnails Brake lights do not work, but they light up-6th-gen-brake-lights.jpg
Old Mar 1, 2012 | 07:04 AM
The 7th-gen has a lot more stuff done with CAN-bus rather than discreet circuits, but I don't know about the brake lamps. I sold that Helm book after I sold the 03 Accord. But it sure seems worthwhile to check the fuses.
Old Mar 1, 2012 | 02:37 PM
Thank you guys for your help.
And there are no warning lamps for the brake lights.
I'm not an electrician or an expert on circuits, so I'll find a buddy to take a look at this. I'll make an update once something develops.
Again, thank you.
Old Mar 1, 2012 | 05:08 PM
Well, unbeknownst to me, my grandpa brought the Accord to the dealer and they simply unplugged and re-plugged the brake light bulbs. No charge.
-- Problem Solved --
Old Mar 2, 2012 | 05:40 PM
Glad you got it.....for the record I found this diagram for the 03-05 Accords...I think the 06's went to led's.
Attached Thumbnails Brake lights do not work, but they light up-7th-gen-brake-lights-03-05.jpg
PJ_STYLES_95AccordEx
Jun 7, 2011 05:40 PM
dbaone
Oct 12, 2008 01:37 PM
96honda96
Mar 24, 2008 02:00 PM
6genex
Sep 16, 2007 11:58 PM
