brake not allowing shift from park
Old Jan 14, 2009 | 10:30 PM
jessecolter's Avatar
Default brake not allowing shift from park
With my 93 Auto I'm suddenly not hearing the click under the shifter when I apply the break, it did this once when it was cold but now all the time, I have to use the shiftlock overide. I checked all the fuses.. any ideas?
Old Jan 15, 2009 | 06:37 AM
Default RE: brake not allowing shift from park
Check for your brake lights to light up. If they dont, look for a bad switch - or loose/dirty/corroded plug for its wire.
Maybe a fuse, but I dont know WHICH fuse that is for 93.
Old Jan 15, 2009 | 04:18 PM
The brake lights are still coming on.
Old Jan 15, 2009 | 04:37 PM
finch13's Avatar
The shift lock solenoid is probably bad or frozen if the switch is working fine. Double check the wiring on it or the fuse like Jim suggested.
Old Jan 15, 2009 | 04:53 PM
As finch said, examine the shift lock solenoid. There is a 3-pin connector on the solenoid. Use a volt meter to test the connector on the outside pins (can't figure out what the middle pin is for). You can download a 91 shop manual from the Online threads link in the DIY section. This will help a lot.
Basically, a voltmeter should read 12V when you try to shift the car out of park by touching the volt meter leads to those two outside pins. If it does, then the solenoid is broken or frozen. Maybe some WD-40 would loosen it up.
rudeg
Dec 31, 2015 07:23 PM
Dr. Drivability
Mar 20, 2014 09:48 AM
campervan12000
Jun 15, 2011 07:23 AM
ally
Feb 10, 2008 06:20 PM
mori0203
Aug 16, 2006 05:54 PM
