brake pad and rotor suggestions
Old Jun 16, 2014 | 07:33 PM
Brent Paul's Avatar
A little brake squeal doesn't bother me. I drove over a year with squeaky brakes in my last car. I know I won't get the cheapest pads available. I have been reading lots of reviews and lots of people claim the aftermarket pads get better grab. Spending extra money on pads doesn't bother me if I get more performance.
Old Jun 16, 2014 | 09:14 PM
bayn8v's Avatar
If you can find a set of Performance Friction pads for your application, they are worth their weight in gold!!! Tremendous increase in pedal firmness, amazing bite and no fade. I was blown away by the set I put on my '10 Civic and I also used powerstop cross/slotted rotors but brakeperformance also has good rotors and pads as well
Old Jun 16, 2014 | 11:22 PM
Brent Paul's Avatar
Thanks everyone for your input. I never realized there were so many aftermarket brake manufacturers. Now the search begins....
Old Jun 17, 2014 | 09:05 AM
LS-300's Avatar
When it came time to replace my 99 Accord brakes I purchased Brembo rotors and PBR/Axxis Ultimate pads. After doing this I was amazed at the difference. The stopping power was fantastic! This is a daily driver my wife uses and even she noticed the difference. The car would stop quickly without wheel lock up. Just make sure you "bed" your new brakes to get the most out of them.
Old Jun 17, 2014 | 10:34 AM
Talking Good Info
You also know that when the wife is Happy that you are also Happy..Good post.
Old Jun 18, 2014 | 10:54 AM
Brent Paul's Avatar
LS that is exactly what I want.
I don't think I can afford brembo this time around.
I see some people put in bigger calipers too.
Is that necessary or are the stock calipers fine?
Old Jun 18, 2014 | 11:32 AM
  #17
djkurious's Avatar
Originally Posted by Brent Paul
What pads and rotors do you have and would you recommend them.
I currently use Duralast gold pads and Wearever rotors.
Advance Auto parts has nice coupon codes. Duralast gold pads are ceramic and have lifetime warranty.
I am a daily "hard on the brakes" driver.
Old Jun 18, 2014 | 10:10 PM
  #18
RobinsonRicer's Avatar
Bigger calipers aren't necessary unless you're doing some serious racing or modding. Think of it as more weight for your engine to haul around.
If brembo is outa your budget then stoptech/centric or ebc are the next cheapest.
Old Jun 18, 2014 | 10:34 PM
  #19
Brent Paul's Avatar
A good explanation thank you.
Old Jun 19, 2014 | 07:43 AM
  #20
Half-fast's Avatar
Regardless of which pad you choose, proper conditioning will help them work well, and last longer. With the exception of racers, I don't know of a single person who "beds" their brakes properly. I am sure they are out there, but it's few and far between.
From my perspective, slotted and drilled (aka precracked) rotors are a useless gimic to get people to spend more cash for zero return. In my 5th gen race car that sees use extremes a street car never will, gets the bottom of the barrel cheapest rotor I can find. I replace them with every pad change and bed them correctly.
I can't comment on pad choice as my application is different. I yield to others on that.
