brake problem
Old May 10, 2009 | 06:59 PM
tomnbarbara
Default brake problem
i replaced the rotors pads drums twice when i press the brakes the steering wheel shakes at speeds around 25 30
i also replaced front wheel hubs and bearings
and all bushings ball joints springs struts axles new tires
im woundering if maybe i put the wrong pads
it also seems to surge when i put the parking brake on while rolling
im lost now oh sorry its a 88 honda accord
any help?
Old May 10, 2009 | 11:20 PM
jax_mugen_si
well since itd be hard to get factory stuff for that accord i would take it on a lift and double check everything to make sure nothign is loose and also take the brake pad box to the store to double check the part number and make sure its for ur car
Old May 11, 2009 | 12:57 AM
Arrow
Re-check your work and re-do all over again..and like jax said make sure you have the right parts..if Im thinking right , I'm thinking calipers..see if the pads are already dragging on those new rotors...
rudeg
Dec 31, 2015 07:23 PM
aznofthe205
Feb 11, 2009 06:15 PM
J2Performance
Jan 15, 2008 04:29 PM
98accord98
Sep 8, 2006 01:25 AM
