brake squeal
Old Apr 27, 2010 | 05:40 PM
jerryhonda's Avatar
Default brake squeal
Hi I am new to this site. I have a 1996 accord and just replaced the front and rear brake pads. Prior to this I have had no brake noise. Now when I step on the brakes at low speed I get a high squeal noise. I have tried brake silence putty on the back of the pads. I also tried to get the front shims to fit better on the shims. And still squeals. The pads on the front have shims on it. do I need to put the factory shims on also? These are pep boys special and are semi mettalic. Any suggestions. I was thinking of taking off the factory shims. Oh and rotors seem to be fine.
Jerry
Old Apr 27, 2010 | 05:42 PM
deserthonda's Avatar
go with factory pads..if still noisy after that, resurface the rotors
Old Apr 27, 2010 | 11:20 PM
kris_loehr's Avatar
Aftermarket pads take some research to find a set that works well. I use the Honda ones and use the gray anti seize on the contact points and between the shims. I have never had one make noise. If you look had enough I believe you can find a source for the factory ones by brand but I think the price is not much different.
Old Apr 27, 2010 | 11:29 PM
finch13's Avatar
Cheap pads squeal.
Did you grease the clips that the pads slide in? Did you pull out the caliper slide pins, wipe them off and put fresh grease on them? You should use a high temp, synthetic grease for brake parts.
Old Apr 27, 2010 | 11:37 PM
Make sure evrything is cleaned up before you put it all back together also..
Old Apr 28, 2010 | 04:37 AM
jerryhonda's Avatar
Thanks for the input. Will try to use the pads I have and put anti squeak between pads and shims. If not then will have to go with factory pads.
Jerry
Old Apr 28, 2010 | 10:52 PM
jerryhonda's Avatar
Default brakes
put anti squeal on back of pads, and thenput shims on.Then I drove to work and no squeal.All is good. Thanks for all the help.
Jerry
Old Apr 28, 2010 | 11:42 PM
hondadude's Avatar
I'll stand by my all time favorite pads "Wagner ThermalQUIET"
Cinci90
Jan 19, 2009 08:08 PM
TexasHonda
Aug 23, 2008 03:30 PM
will93
Mar 17, 2008 07:21 PM
91boz
Jan 1, 2007 12:39 AM
ckebottle
Sep 23, 2006 09:35 PM
