Brakes Acting Strange
Old Oct 18, 2011 | 06:02 PM
500$accord's Avatar
Default Brakes Acting Strange
I just replaced all of my rotors ( even the captive front rotors ) and I was horrified when I started to get a brake pulse about 1 month afterward... and I don't drive very fast where I would need the brakes much.
The pulse seems more in the steering wheel than the brake pedal. Could it be something other than warped rotors??
Old Oct 18, 2011 | 06:30 PM
Possible loose/worn tie-rod ball jt, upper BJ, or lower BJ. Check wheel for looseness by pushing/pulling at bottom and side of tires. Any looseness is cause to investigate further.
Old Oct 18, 2011 | 06:54 PM
500$accord's Avatar
Thanks Texas Honda.
I have checked the wheel for play the best I could. The passenger side upper arm is new aftermarket, the ball joints are new honda and I also replaced the sway bar bushings and links. Everything felt great... for a while until this most recent change. I don't notice much of a problem while driving, only braking.
The feeling that I get while driving is probably more of a shudder like the brakes only work every half rotation of the tire. really strange. I guess tie rod ends are more likely. Should I be able to notice bad tie rods by pushing/pulling on them?
Old Oct 18, 2011 | 07:21 PM
Yes, any play in inner or outer ball jts could explain shudder/vibration.
Old Nov 14, 2011 | 12:04 PM
500$accord's Avatar
Default CV joints???
Although I haven't identified the cause of my shudder, I did notice today that one of my CV joints on my not too old aftermarket replacement axles must be gone. I went from a series of light taps on the highway to a loud banging at just about all driving conditions over 20 MPH within a mile. worse on right turns, but still present going straight and left turns. The banging continued even as the car was slowed down "slowly" up until a dead stop. I have had CV joint issues on other cars, and I suspect this as the cause. Curse you reman axles!!!!
I am hoping that when I replace the axle or axles, this will eliminate my brake shudder.
Old Nov 14, 2011 | 05:09 PM
k24acura's Avatar
Seems as if when the brakes were done they were not seated properly. Clean off the hub and rotor. See if the braking is better. if the boot is broken replace it or axle.
Ronracer
Apr 8, 2010 09:23 AM
Drkmstr104
Aug 26, 2009 03:59 AM
drummer1279
Aug 18, 2006 12:21 AM
phaders
Jan 5, 2006 05:17 PM
