brake's lights won't turn off
Old Jun 20, 2011 | 10:20 PM
kennilope's Avatar
Default brake's lights won't turn off
All of the brake lights won't turn off even the car is off and ignition key is out.
HELP.
How to fix it?
Old Jun 20, 2011 | 10:28 PM
Got a "blue" crayon thing in the floor board.....pedal stop is gone. There is a fuse in the underhood fuse panel you can pull to keep the battery from going dead. Then go to the dealer and get a new stop....46505-SA5-000......
Old Jun 21, 2011 | 08:00 AM
kennilope's Avatar
How hard it is to replace this part?
Any advise would be great.
Old Jun 21, 2011 | 06:11 PM
If that is the issue, pretty sure it is. Very simple, the hardest part is getting your head down where your feet go while driving....Once you confirm the "stop" is gone and you have the new one. Get your head down by the pedals, use one hand to press the brake down, insert new plug.....done. Did this for a co-worker ~ 2 months ago, took 5 minutes-tops...ok there was the 5 minutes in the morning where I opened the driver door and saw the "crayon"/plastic thing on the floor under the pedals (all I needed to see, knew what the problem was), opened the hood and pulled the fuse for them so the battery didn't go dead.
Old Jun 22, 2011 | 08:12 AM
kennilope's Avatar
Thanks..
I thought I need the switch but I only need the stopper.
I ordered the part number provided.
the switch they want to charge $37.. the stopper is $4.10
Old Jul 14, 2022 | 07:17 PM
sunhonda's Avatar
I see this is an old post, but it's a new problem for me, hoping to get some help. I found the broken "crayon" pieces under the brake pedal. When I got under there I couldn't tell if the part should be pressed in the hole from the driver's seat side or from behind from the engine side. Mechanically it seems to make sense to put it in from the engine side of the hole, but the parts diagram looks like it's showing it going in from the driver's seat side. Thx in advance.
Old Jul 14, 2022 | 10:28 PM
The flat portion or the disc side faces the brake pedal switch. Based on your question, it would be installed from the driver's seat side where the push-pin/clip is pointing away from the brake pedal switch when installed.
Old Jul 15, 2022 | 12:21 AM
sunhonda's Avatar
Yes, that makes more sense than what I was initially thinking -- so the flat part of the "grommet" is sitting between the switch head and the metal of the brake-pedal arm and the pointed end is facing the engine. Thx!!
jrparks
Aug 21, 2017 09:53 AM
fudads
Feb 27, 2013 07:36 AM
SirJohnIII
Feb 26, 2013 05:11 PM
JohnnyQ
Oct 3, 2012 11:54 AM
